Hi All,
I'm using a contained mashup receiving data from service x.
Eventually, I need this conteined mashup receive data from service y as well...
How can I create this control?
Anselmo.
Hi @Saitoisonfire,
Ok, I can think in two cases here:
Hope it helps you,
Vinícius Xavier.
Hi @Saitoisonfire,
Hope it helps you,
Vinícius Xavier.
Hi @vxavier,
It is the second case, I have to populate the same priority.
I thought it could have an easier way using some kind of flux manager instead of a lot of "if".
But I think this is the solution.
Anselmo.
I checked here, Event Router will do the job.
The Events Router Widget allows a user to bind multiple sources to one target, and each time a source is updated, the output is updated accordingly.
