I have a templateThing which configuration has a password parameter. Thing which are created dynamically from this template get its password from the configuration of another thing.
The problem is, i don't know how to copy this password.
According to this topic
https://community.ptc.com/t5/ThingWorx-Developers/Password-Not-Copy/m-p/608940#M36151
it seems to be not possible.
Is it right ?
If no, how can i do ?
If yes, does anybody have a suggestion to achieve that ?
Thanks.
The community post you found is right.
This is per security policies, you cannot copy it.
Best Wishes!
Teresa
Hi @cbaurand.
If one of the previous responses allowed you to find a solution, please mark the appropriate one as the Accepted Solution for the benefit of others with the same issue.
Regards.
--Sharon
