I am following this tutorial PTC
When Run the following command to deploy the ThingPredictor JAR file from the command line:
java –jar thingpredictor.jar server prediction-with-analysis.yml
I am getting this error
Could not find or load main class
Please let me know what I am missing here?
Azim
Hi Azim
one common issue that leads to this error is a problem durign copy and paste of the command.
Try retyping the - character in front of jar in java –jar thingpredictor.jar server prediction-with-analysis.yml
If it still does not work, please post a screenshot of the command and error so we can see the full message.
Thank you
Kind regards
Christophe
Hi Azim
Thank you
Kind regards
Christophe
