I have a grid widget with dynamic columns. Because of this, I am using the JSON configuration to map instead of a standard datashape. With that said, I cannot get the footer to enable on the grid. The examples in the GridAdvancedExampleServices Thing use
"enableFooter": truebut this doesn't work. In the grid widget it is called "ShowFooter" so I tried changin "enableFooter" to this and "showFooter" with no luck.
How do I enable the footer via the JSON configuration?
Hello @JustinOberle1 ,
I have taken a look at the issue of using Grid Widget with JSON defined table.
There appears to be a few items with getting the configuration correct.
Here are the steps I believe you need to follow. Please review and let me know if you have questions.
"enableFooter": true,
Let me know if you have any questions
Pehowe
Hi @JustinOberle1 look at the link below, and let us know your ThingWorx version details.
This is version 9.6.
This doesn't work in my version. enableFooter = true does nothing. The example services work, but not the footer portion does not. I think this is probably a bug.
I did a workaround by putting totals in the top row of the returned data. I was trying to avoid this since this grid is editable. With that said, if they try to edit the totals, it will simply error out and do nothing. Not ideal, but it is fine.
Pehowe
Hello @JustinOberle1 , I found the other flag which was added for the footer
"enableHeaderRowInFooter": true,
This will allow the grid footer and display the header row on the footer.
PEHOWE
Hi @JustinOberle1 ,
It appears that there is a reply that answers your question. For the benefit of other Community Members who may have the same question, it would be great if you could designate it as the Accepted Solution.
In the event that this response did not answer your question, please post your current status so that we can continue to support.
Thanks for using the PTC Community!
Charles
