Hi All,
what's the best way to create dummy data?
I need a step by step of that for newbie reasons.
Any tips?
Thanks!
Anselmo.
I already found what I needed here : https://www.ptc.com/en/support/article?n=CS181457
Anselmo Saito: From the details it is not clear in what context you are looking to create dummy data. One way used commonly is to use Edge SDK code ( Java/C/.NET) to get random data into remote things which could be used to test cases. Please refer URL for more details about Edge SDK.
You can also make REST Calls for setting/getting different data into ThingWorx system and can refer API help section for more detail.
Do let us know in case you are looking to create dummy data for specific set of functionality or use case.
-Durgesh
