Hi All,
I want to create website like menu similar to screenshot below using thingworx mashup.
I had tried creating the same using thingworx widget like (tabs). But the look and feel of the mashup created using widgets is not the same.Please let me know if there is any other widget which I can use or I need to create a custom widget or any other approach which I should follow.
