Custom Object :: Launch a Bomgar Session from Axeda
dwebster1
* Launch a Bomgar Session from Axeda
* (1) get Bomgar ID & check logged in
* (2) generate session key and external key
* (3) create / update software package with explorer execute instruction
* (4) deploy package against supplied asset
Add the following Paramters to the Action Custom Object
user
pwd
asset
import net.sf.json.JSONObject
import groovyx.net.http.HTTPBuilder
import static groovyx.net.http.ContentType.*
import com.axeda.drm.sdk.scripto.Request
import com.axeda.services.v2.AssetReference
import com.axeda.services.v2.Model
import com.axeda.services.v2.ExecuteApplicationInstruction
import com.axeda.services.v2.SoftwarePackage
import com.axeda.services.v2.DeploymentType
import com.axeda.services.v2.SoftwarePackageCriteria
String VERSION = "2.0.0.0"
String NAME = "LaunchBomgar"
String BOMGAR_HOST = "https://your.bomgar.box.com/"
String BOMGAR_PATH = "api/command.ns"
String BOMGAR_ID = "get_api_info"
String BOMGAR_SESS = "generate_session_key"
String BOMGAR_LOGG = "get_logged_in_reps"
def toJSON(msg){
    msg = [ response: msg ]
    toJSON = ['Content-Type': 'application/json', 'Content':JSONObject.fromObject(msg).toString(2)]
try
    String sBomgarID, sShortKey, sURL, sModel, sSerial, sExtKey, sError
    Boolean bLoggedIn=false
    def params = Request.parameters?.size() >2 ? Request.parameters : parameters
    String sUser = params.user
    String sPwd = params.pwd
    String sAssID = params.asset
    // find asset
    Asset myAsset = bridges.assetBridge.findById(sAssID)
    if (myAsset == null){
        logger.info "Asset ID not found " + sAssID
        return toJSON("Asset ID not found " + sAssID)
    // find Model
    Model myModel = bridges.modelBridge.findById(myAsset.getModel().getSystemId())
    if (myModel == null){
        logger.info "Model not found"
        return toJSON("Model not found")
    sSerial = myAsset.serialNumber
    sModel = myModel.modelNumber
    sExtKey  = sModel + "|" + sSerial
    // get my Bomgar rep id
    def Query = [username:sUser, password:sPwd, action:BOMGAR_ID]
    def bomgar = new HTTPBuilder(BOMGAR_HOST)
    bomgar.get ( path: BOMGAR_PATH, query: Query, contentType : XML ) { resp, xml ->
        sBomgarID = xml.user_id.text()
        sError = xml.text()
    if (sBomgarID==""){
        logger.info "Bomgar (" + sUser + ") " + sError
        return toJSON("Bomgar (" + sUser + ") " + sError)
    // check that I'm logged in
    Query = [username:sUser, password:sPwd, action:BOMGAR_LOGG]
        if (xml.rep.size() > 0) {
            xml.rep.each {
                if ( sBomgarID == it.@id.text() ) bLoggedIn = true
    if (!bLoggedIn){
        logger.info "Bomgar (" + sUser + ") Not Logged In"
        return toJSON("Bomgar (" + sUser + ") Not Logged In")
    // create a Bomgar session key
    Query = [username:sUser, password:sPwd, action:BOMGAR_SESS, type:'support', queue_id:'rep:' + sBomgarID, external_key:sExtKey]
        sURL = xml.key_url
        sShortKey = xml.short_key
    if (sURL.size()<5){
        logger.info "Bomgar Session not generated"
        return toJSON("Bomgar Session not generated")
    // search for existing package
    SoftwarePackageCriteria softCrit = new SoftwarePackageCriteria()
    softCrit.setName(NAME+sSerial)
    softCrit.setVersion(VERSION)
    packages = bridges.softwarePackageBridge.find(softCrit)
    // delete old packages
    bridges.softwarePackageBridge.delete(packages.getSoftwarePackages())
    // create execute instruction which runs explorer on asset
    ExecuteApplicationInstruction execIns = new ExecuteApplicationInstruction()
    execIns.setPathToExecutable("explorer")
    execIns.setAsyncExecution(true)
    execIns.setArguments("\"" + sURL + "\"")
    // create simple software package
    SoftwarePackage softPack = new SoftwarePackage()
    softPack.setName(NAME+sSerial)
    softPack.setModel(myAsset.model)
    softPack.setVersion(VERSION)
    softPack.instructions.add(execIns)
    result = bridges.softwarePackageBridge.create(softPack)
    if ( ! result.isSuccessful() ) {
        logger.info "Package error " + result.toString()
        return toJSON("Package error " + result.toString())
    // create software deployment
    Deployment deploy = new Deployment()
    deploy.setSoftwarePackage(softPack)
    deploy.setType(DeploymentType.MANUAL)
    AssetReference assRef = myAsset
    deploy.assets.add(assRef)
    result = bridges.deploymentBridge.create(deploy)
        logger.info "Deployment Error" + result
        return toJSON("Deployment error " + result)
    else
        logger.info "Session Deployed " + sShortKey
        return toJSON("Session Deployed " + sShortKey)
catch (Exception e){
    logger.error(e)
    return toJSON(e.toString())
0 REPLIES 0
