Custom widget installation issue
RT_8054652
2-Guest
Widget successfully added for import but when i click on import button following error occur.
Help if anyone created custom widget.
gnandyala
(To:RT_8054652)
Where have you got this extension from.
Check if there are any requirements for importing the extension.
Hi Gautham,
I had take help from HelloWorld_ExtensionPackage . Here are the files which i had modify with my widget named dchart.
Please help in resolving this.
ytella
(To:RT_8054652)
Hi Ritu Tomar,
Please refer to the following article for troubleshooting custom widget extension import errors in ThingWorx:
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS194051&language=en&posno=2&q=ui%20does%20...
Hope this helps to resolve the installation issue!
Hi Yamini,
Still getting same error.
I had followed all steps everything is as per to the article.
