Hi
I am converting timestamp to datetime format with basetype DATETIME with the code "var date = new Date(Timestamp * 1000)". The result of it is being saved in an datafield of DATETIME basetype. I want to extract the date part of the result since i want to apply aggregate function on it. To extract the date part of the column, I am using (getFullYear(),getMonth(), getDay()) methods. But it gives me an error "Cant find getFullYear() function in "Wed Jan 15 2020 06:26:30 GMT+0530 (IST) "" Even though my DATETIME is being stored in the format YYYY/MM/DD HH:MM:SS why is it pointing to the GMT format to extract the DATE object
A way aorund it would highly be appreciated
regards
Woks fine for me using, for example:
me.date1 = new Date(1579069590 * 1000);
var result = me.date1.getFullYear();
Could you please share your full code? Also, what is the ThingWorx version that you are using?
for(i = 0; i<result.getRowCount(); i++){
var date = new Date(result.rows[i].Timestamp * 1000);
var year = date.getFullYear();
var month = date.getMonth();
var day = date.getDay();
result.rows[i].Timestamp = year+'-'+month+'-'+day;
This is the code I am using I am getting the timestamp from csv file which I am reading and converting it into DATETIME in the same infotable under Timestamp datafield.
I am using 8.3.3 version
What is the data type of the Timestamp field of the datashape on which the result infotable is based upon?
I am still unable to replicate it. If you just want a string representation of your date then you could use below code(dateValue is of type DATETIME):
var result = dateFormatISO(dateValue).substr(0,10);
Hi
Datatype of the Timestamp field is DATETIME so when I upload my CSV the EPOCH Timestamp automatically converts into DATETIME format but i multiplied the result with 1000 to get the present date of timestamp.
If i get a string format of the DATETIME will I be able to feed it in the Time-series chart?
In this line, you seem to be assigning a string to Timestamp
Hi
So what will be the exact solution for the problem?
If you want to remove the time part of the datetime property while displaying it in a time series chart, you can do this by specifying the appropriate XAxisFormat.
As far as I know, DATETIME will always have a time component.
As per this article, aggregate functions cannot be applied to dates in ThingWorx.
Also, I noticed that you are using getDay() which will give you the day of the week and not the date(getDate()).
