Data Export Not Working in Thingworx 7.4.0-b159
tsharma
Hi All,
I tried exporting my infotable data using the inbuilt export widget (with proper bindings), but it is not working.
So, I imported Data Exporter Extension v1.0 from Thingworx Marketplace, and then tried exporting my infotable using it (with proper bindings), but still it's not working.
Can anyone please suggest if something is wrong with the compatibility of the inbuilt widget/marketplace extension and Thingworx Composer version...?  or any workaround to export my data...?
posipova
20-Turquoise
(To:tsharma)
Does it error out? Could you please check and attach applicationlog.log locatied in ThingworxStorage/logs ?
You might want to try to manually export your data. More info on that here.
