With the Data Export Widget, it allows you to export data.
There is a slight problem which we are encountering, The file's name is always Data(x).csv.
We would like to have a custom name for the file instead of Data(x).csv.
We would want the file to be "now()+name".csv
Does anyone know how we could do that ?
I assume to change that I will need to change the code of the extension. But the extension's folder contains .jar and I don't know how to open these in order to modify the code inside.
Hi Frederik Grondin,
Yes, as per my understanding; this will require a creation of a new extension with updated code.
There are decompilers available on Google which decompiles the code inside .jar files. But I am not sure if this is ethical.
I hope it helps.
Hi Frederik,
There is an Extension named CSV Parser, I suggest you to try that.
BR,
Lily
