Are there any built in tools that allow for filtering with drop down options? In order to us the datafilter widget, a user must have good knowledge of names and what properties to use. I could build a custom dropdown that passes the selected item to a service that executes a query, but I want to make sure that there isn't some sort of built in solution that I could be using. Thanks!
Hi Brian,
On the marketplace there's a Autocomplete widget ( http://marketplace.thingworx.com/downloads/autocomplete/ ), maybe that's what you need...
Best Regards,
Carles.
