The message you are trying to access is permanently deleted.
The Data properties and Functions tab which use to be available in right bottom dock of mashup builder went invisible and I couldn't find any clues to get it back. I have attached a snap for reference, does any body know how to fix this?
Hello @kbabylav
Can you please help me with version of your Thingworx?.
Are you facing the issue in this particular mashup or any other mashup too?
Om Dukiya
Hello Om Dukiya,
Thanks for your reply. Am facing the same with all mashups (mashup builder) opened with my credentials. And the version am using is 8.5.
Hello @kbabylav
Can you please try importing the following mashup and let me know if you can see the functions and validators?
Om Dukiya
Hi @kbabylav, If its a general problem try tomcat restart and tomcat cache clear . If a particular mashup issue try duplicating that mashup and see the behaviour
You may check:
1. Can you add new Data to the mashup
2. Check F12-console or F12-network for missing resource
3. Check in incognito mode to avoid browser cache, and see if it still exist
