I want to capture data change event of remove device property. On that event, need to capture values of different properties at the same time. Is this possible in ThingWorx?
I'm not sure exactly what you mean by "capture values of different properties". Are you saying that you need other properties which are also remote properties in a service that you want triggered from a data change event on a separate property?
This should be possible, for sure. Are you seeing issues with this?
