C SDK Axtls connect tomcat V8.0.37 with certication failed
dchang1
hi , I have a problem with C SDK.  I use AxTLS     , In the Server ,I use the certification.
  in the main.c
      int16_t port = 443;
twApi_SetSelfSignedOk();
  twApi_DisableCertValidation();
I use wireshark. I can see that the Server kills the connection. Can you give me some reason that why the server kill the connection?  Thanks!
the server.xml
5 REPLIES 5
Aanjan
(To:dchang1)
Daniel, please do post the logs from the C SDK as well. Does it error out with Error Code 1001?
dchang1
(To:Aanjan)
Hi , Aanjan,
    My problem has been solved , TLS handshake succeed. and the server show isconnected== ture; but the data are not correct. The server hints:
Error browsing properties. Be sure the remote device/server is connected and configured properly
An Invalid Property Value Was Sent To [Water Pump1 Property: [null]
Can you tell me what' the reason? Or where is my code error. In addtion if I do not use the TLS , the property is correct.
dchang1
(To:dchang1)
Aanjan ,  I do not use the log, I debug the C SDK, and trace  "return TW_SOCKET_INIT_ERROR"    , twTLS.c: line 120
Aanjan
(To:dchang1)
Daniel, how are the properties set? The 'null' error message you're getting implies that the C SDK doesn't know which property to send values to (as nothing has been bound yet). Are you binding to that Thing using Identifiers?
dchang1
(To:Aanjan)
My problem is solved.
What type is DATETIME ?  what is size of DATETIME?   In the server the property timestamp is 1970-1-1 0:12:xx . How can I modify the time in C SDK?
