Is there a way to get the data value to display above the bars/lines in time series chart and label charts like the images below?
Jenna, please take a look at the Custom Chart Widgets available in the ThingWorx Marketplace. The Bar Chart included has a property called 'ShowValues' that displays values above each bar when using single-series.
hi Anajan ,i have the same requirement,the Custom Chart Widgets is not a perfect solution,is there a way to set on the label chart
