Data livestream from raspberry pi to Thingworx
Re: Data livestream from raspberry pi to Thingworx
Thank you Durgesh Patel​, that was a good point, the connection is now successfull.
But now I get another error that it cannot find the python script which reads the sensor data. It is saved in the correct direction /home/pi.
Ravi Upadhyay​, it seems the javassist is not required to run the programme.
And I think it's build with eclipse. But that's the problem it is not my jar file and I'm not very familiar with java. I had a WebEx call with the PTC software engineer I mentioned before. In result to that he send me the jar file, the python script and a short tutorial word document. I tried since then to get a running script.
The error:
