What should be the datatype for negative numbers in thingworx analytics dataset configuration. Since my data there will be both positive and negative numbers. I tried with DOUBLE and INTEGER both seems to fail with below error
Unexpected character ('-' (code 45)) in numeric value: expected digit (0-9) to follow minus sign, for valid numeric value
at [Source: org.glassfish.jersey.message.internal.ReaderInterceptorExecutor$UnCloseableInputStream@16768b7b; line: 1, column: 3]
Azim
Hi Azim,
Underneath article might solve? the issue.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS229798&lang=en_US
Br.
Asia
Hello Asia,
This is what I get when I click on the link which you have mentioned.
Error:Document 229798 is not customer viewable as it is an internal PTC document.
Azim
Hi Azim,
While the document yet cant be viewed from your side, I have email you directly with the document information.
Br.
Asia
