Greetings, I'm using Thingworx 5.0 SP2:
Logging Issue #1:
Even though the Application Log monitor settings are set to DEBUG, my logging statements are not getting written to the log unless they are either warn or error messages. I a couple extensions i've imported and the debug messages in those extensions are not getting written to the application log file. If i change them to warn or error, then they do getting written to the log file.
How do i get the debug messages in my extensions to get written to the Application Log file.
BTW, they use slf4j for logging. And I log using logger.debug(msg, exception); or logger.debug(msg).
Logging Issue #2:
I've also noticed that only the message is logged and in the console only the first line of the message is rendered.
Is there a way to enable logging of the stack trace as well?
