Default Reset Button in ptcs - chartline was not working properly
SC_10752357
Logic: Based on Selection of Dropdown list the values in ptcs-chartline will change.
Problem:
Unable to predict when the Default Reset Button in ptcs-cahrtline was working. It will work for some data and for some period of time.
@SC_10752357
I tested LineChart widget locally, reset button work fine.
The issue may depends on your mashup design.
Can you supply a demo mashup and reproducing steps so we can locally reproduce the issue ?
