Developing workflow in Workflow Builder
mak1729
Participant
I have made a simple workflow and validate it.But It is not showing in Workflow Management.Can anyone explain how to correctly make a workflow and suggest some tutorial for thingworx utilities ?
Re: Developing workflow in Workflow Builder
Workflow Management does not display Workflow definitions (the Workflows you are building).  It allows you to view Workflow instances which are initiated when the Alert/Event that was configured for the Start nodes of their associated Workflow definition are triggered.   The Workflow definition that you created in Workflow Builder can be seen when you click the 'Open' button in Workflow Builder.
Check out the upcoming Expert Session: Understanding ThingWorx Navigate Licensing in Community "Customer Events" section.
