Do a stream query with tags filter
cbaurand
According to this documentation,  https://support.ptc.com/help/thingworx_hc/thingworx_8_hc/en/index.html#page/ThingWorx/Help/Composer/Things/ThingServices/QueryParameterforQueryServices.html,
we should be able to do a query with those filters:
TAGGED or NOTTAGGED filter
var query = {
            "fieldName": "tags",
            "type": "NOTTAGGED",
            "tags": [
                        "vocabulary": "Applications",
                        "vocabularyTerm": "Testing"
                        "vocabulary": "Plants",
                        "vocabularyTerm": "Sedona"
or with those:
var query =
    "filters": {
        "type": "And",
        "filters": [
                "type": "GT",
                "fieldName": "Duration",
                "value": "12"
                "type": "TaggedWith",
                "tags": "MaintenanceIssues:PowerOutage"
But it seems that none of them works with tags. Can someone confirm this troubleshouting?
Thanks.
mnarang
(To:cbaurand)
I have something like your second query working absolutely fine. Can you replace "TaggedWith" to "TAGGED" in your second query and test it again ? In your case it should be like:
var query =
"filters": {
"type": "And",
"filters": [
"type": "GT",
"value": "12"
"type": "TAGGED",
TomasCharvat
(To:mnarang)
Hello  mnarang,
Thanks for this hint,
I always tried to use TaggedWith/NotTaggedWith from TWX Help documentation and my queries still did not work.
This helped me a lot!
Tomas
Hi @TomasCharvat
There is a ticket already opened with R&D to investigate why TaggedWith query parameter does not give the expected result. I will update here once I get a response on the ticket.
Sachin
