Docker with Thingworx + PostgreSQL fails to start
A_Macierzynski
Hi!
I am struggling a lot with OOTB Docker images which PTC provides for Thingworx 8.4 & PostgreSQL setup.
What I am trying to do is to run Docker containers on my Ubuntu 18.04 Virtual Machine.
Everything seems to be installed correctly, but it fails to start with this error log:
platform_1 | 2019-08-14 07:29:28.639+0000 [L: INFO] [O: c.t.p.p.PostgresDatasource] [I: ] [U: SuperUser] [S: ] [T: main] Reading configuration from configTableCol
platform_1 | 2019-08-14 07:29:28.997+0000 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: main] Managers...INITIALIZED
platform_1 | 2019-08-14 07:29:29.000+0000 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: main] Database initialization started...
postgresql_1 | ERROR: relation "system_version" does not exist at character 128
postgresql_1 | STATEMENT: SELECT server_name, server_code, model_schema_version, data_schema_version, major_version, minor_version, revision, build FROM system_version order by pid desc limit 1
postgresql_1 | ERROR: current transaction is aborted, commands ignored until end of transaction block
platform_1 | 2019-08-14 07:29:29.276+0000 [L: ERROR] [O: c.t.p.p.PostgresModelExceptionTranslator] [I: ] [U: SuperUser] [S: ] [T: main] [message: ERROR: relation "system_version" does not exist
platform_1 | Position: 128]
docker-compose-postgres.yml:
Spoiler
version: '2.2'
services:
  postgresql:
    image: thingworx/postgres-db:latest
    ports:
      - "5432"
    healthcheck:
      test: pg_isready -U postgres
      interval: 15s
    environment:
      - "TWX_DATABASE_USERNAME=twadmin"
      - "TWX_DATABASE_SCHEMA=thingworx"
      - "TWX_DATABASE_PASSWORD=password"
    #volumes:
      #- "/home/devadmin/twx/ThingworxPostgresqlStorage:/home/ThingworxPostgresqlStorage"
      #- "/home/devadmin/twx/postgres-data:/var/lib/postgresql/data"
  platform:
    image: thingworx/platform-postgres:latest
    healthcheck:
      test: curl -s -w '%{http_code}' -U 'bad:creds' localhost:8080/Thingworx/Subsystems/PlatformSubsystem | grep -w 401
      interval: 15s
    depends_on:
      postgresql:
        condition: service_healthy
    ports:
      - "8080:8080"
      - "8443:8443"
    environment:
      - "INITIAL_HEAP=2"
      - "MAX_HEAP=4"
      - "DATABASE_HOST=postgresql"
      - "DATABASE_PORT=5432"
      # NOTE: Set TWX_DATABASE_USERNAME, TWX_DATABASE_PASSWORD TWX_DATABASE_SCHEMA for
      # the thingworx database setup that will either be created by the docker image,
      # or connected to if it already exists.
      # NOTE: The following must be set for the Platform to start. This will be
      # the initial Administrator password.
      - "THINGWORX_INITIAL_ADMIN_PASSWORD=Administrator123!@#"
    #volumes:
      #- "/home/devadmin/twx/ThingworxPlatform:/ThingworxPlatform"
      #- "/home/devadmin/twx/ThingworxStorage:/ThingworxStorage"
      #- "/home/devadmin/twx/ThingworxBackupStorage:/ThingworxBackupStorage"
      #- "/home/devadmin/twx/tomcat-logs:/opt/apache-tomcat/logs"
Build.env file:
Spoiler
# Required
JAVA_VERSION=8u201
TOMCAT_VERSION=9.0.17
PLATFORM_VERSION=8.4.4
TEMPLATE_PROCESSOR_VERSION=12.1.0.12
PLATFORM_SETTINGS_FILE=platform-settings.json
# If you wish to build the test DB images for dev/testing for PostgreSQL and
# MSSQL set BUILD_TEST_DBS to true. Otherwise, set to false to disable.
BUILD_TEST_DBS=true
# H2 Builds Only
PLATFORM_H2_VERSION=${PLATFORM_VERSION}
PLATFORM_H2_ARCHIVE=Thingworx-Platform-H2-${PLATFORM_H2_VERSION}.zip
# PostgreSQL Builds Only
PLATFORM_POSTGRES_VERSION=${PLATFORM_VERSION}
PLATFORM_POSTGRES_ARCHIVE=Thingworx-Platform-Postgres-${PLATFORM_POSTGRES_VERSION}.zip
# MSSQL Builds Only - Required Credentials for Build Process
# The Following must be set for MSSQL builds due to how the test DB is created,
# if you have enabled building the test DBs with BUILD_TEST_DBS. The settings
# chosen here must match the variables passed into the ThingWorx Platform on startup
MSSQL_DB_TWX_DATABASE_PASSWORD=
MSSQL_DB_TWX_DATABASE_USERNAME=
MSSQL_DB_TWX_DATABASE_SCHEMA=
MSSQL_DB_SA_PASSWORD=
# MSSQL Builds Only
PLATFORM_MSSQL_VERSION=${PLATFORM_VERSION}
PLATFORM_MSSQL_ARCHIVE=Thingworx-Platform-Mssql-${PLATFORM_MSSQL_VERSION}.zip
SQLDRIVER_VERSION=6.0.8112.200
# AzureSQL Builds Only
PLATFORM_AZURESQL_VERSION=${PLATFORM_VERSION}
PLATFORM_AZURESQL_ARCHIVE=Thingworx-Platform-Azuresql-${PLATFORM_AZURESQL_VERSION}.zip
AZURESQL_SQLDRIVER_VERSION=6.0.8112.200
# Optional to configure. If the Files do not match the pattern, they may need
# to be manually modified.
TOMCAT_ARCHIVE=tomcat-${TOMCAT_VERSION}.tar.gz
JAVA_ARCHIVE=jdk-${JAVA_VERSION}-linux-x64.tar.gz
SQLDRIVER_ARCHIVE=sqljdbc_${SQLDRIVER_VERSION}_enu.tar.gz
AZURESQL_SQLDRIVER_ARCHIVE=sqljdbc_${AZURESQL_SQLDRIVER_VERSION}_enu.tar.gz
TEMPLATE_PROCESSOR_ARCHIVE=template-processor-${TEMPLATE_PROCESSOR_VERSION}-application.tar.gz
 platform-settings.json file:
Spoiler
	"PlatformSettingsConfig": {
		"AdministratorUserSettings": {
			"InitialPassword": "trUf6yuz2?_Gub"
		"ExtensionPackageImportPolicy":
			"importEnabled": true,
			"allowJarResources": true,
			"allowJavascriptResources": true,
			"allowCSSResources": true,
			"allowJSONResources": true,
			"allowWebAppResources": true,
			"allowEntities": true,
			"allowExtensibleEntities": true
		"ContentTypeSettings": {
			"supportedMediaEntityContentTypes" : ["image/svg+xml", "image/png", "image/gif", "image/bmp", "image/jpeg", "application/pdf", "image/vnd.microsoft.icon"]
	"PersistenceProviderPackageConfigs": {
		"PostgresPersistenceProviderPackage": {
			"ConnectionInformation": {
				"acquireIncrement": 5,
				"acquireRetryAttempts": 3,
				"acquireRetryDelay": 10000,
				"checkoutTimeout": 1000000,
				"driverClass": "org.postgresql.Driver",
				"fetchSize": 5000,
				"idleConnectionTestPeriod": 60,
				"initialPoolSize": 5,
				"jdbcUrl": "jdbc:postgresql://localhost:5432/thingworx",
				"maxConnectionAge": 0,
				"maxIdleTime": 0,
				"maxIdleTimeExcessConnections": 300,
				"maxPoolSize": 100,
				"maxStatements": 100,
				"minPoolSize": 5,
				"numHelperThreads": 8,
				"password": "password",
				"testConnectionOnCheckout": false,
				"unreturnedConnectionTimeout": 0,
				"username": "twadmin"
			"StreamProcessorSettings": {
				"maximumBlockSize": 2500,
				"maximumQueueSize": 250000,
				"maximumWaitTime": 10000,
				"numberOfProcessingThreads": 5,
				"scanRate": 5,
				"sizeThreshold": 1000
			"DataTableProcessorSettings": {
				"numberOfProcessingThreads": 1,
				"scanRate": 5,
				"sizeThreshold": 1
			"ValueStreamProcessorSettings": {
				"maximumQueueSize": 500000,
				"scanRate": 5,
			"PersistentPropertyProcessorSettings": {
				"maximumWaitTime": 1000,
				"maximumQueueSize": 100000,
				"numberOfProcessingThreads": 20,
				"scanRate": 25,
Actually I found a solution.
According to the doc those variables:
NEED TO BE THE SAME. I changed it for thingworx everywhere and it is working like a charm.
I have no idea why there are 2 variables exposed, but only one value can be assign to both in one time.
Nevertheless that resolved my issue.
Since it cannot find the relation, it looks like the database schema didn't initialize correctly. I suggest looking earlier in the docker-compose log, up to the point where it executes /docker-entrypoint-initdb.d/db-setup.sh
Constantine
Vilia (my company) | GitHub | LinkedIn
