Does anyone know how to use java api to achieve anomaly detection with Thingwatcher8.0?
weli
Please see my code in attachment,the output of my code is:
CALIBRATING
WAT9999E
Unexpected exception. {Throwable=[NullPointerException: }]
Is isAnomalousValue false
ThingWatcherStat FAILED
It indicates after calibrating the thingwatcher failed.
I used jar install to run resut and training Microservices.  I can see log from training microservice
com.thingworx.analytics.training.core.TrainingRunner: Successfully stored PMML to modelUri "Optional[http://192.168.31.202:8090/results/models/1/models.xml]" for jobId "1"
But I see error in result microservice:
INFO  [2017-07-18 00:16:27,791] io.dropwizard.jersey.jackson.JsonProcessingExceptionMapper: Mapping exception: class javax.ws.rs.WebApplicationException
! com.thingworx.analytics.results.db.EntityNotFoundException: Could not retrieve result [1]
! at com.thingworx.analytics.results.db.ResultsModelDAO.lambda$findSpecific$0(ResultsModelDAO.java:67)
! at java.util.Optional.orElseThrow(Unknown Source)
! at com.thingworx.analytics.results.db.ResultsModelDAO.findSpecific(ResultsModelDAO.java:67)
! at com.thingworx.analytics.results.core.ResultsService.findById(ResultsService.java:44)
! at com.thingworx.analytics.results.resources.ModelResource.retrieveModelXml(ModelResource.java:185)
! ... 61 common frames omitted
! Causing: javax.ws.rs.WebApplicationException: Could not retrieve result [1]
! at com.thingworx.analytics.results.resources.ModelResource.retrieveModelXml(ModelResource.java:190)
! at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
! at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
! at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
! at java.lang.reflect.Method.invoke(Unknown Source)
! at org.glassfish.jersey.server.model.internal.ResourceMethodInvocationHandlerFactory$1.invoke(ResourceMethodInvocationHandlerFactory.java:81)
! at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher$1.run(AbstractJavaResourceMethodDispatcher.java:144)
! at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.invoke(AbstractJavaResourceMethodDispatcher.java:161)
! at org.glassfish.jersey.server.model.internal.JavaResourceMethodDispatcherProvider$ResponseOutInvoker.doDispatch(JavaResourceMethodDispatcherProvider.java:160)
! at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.dispatch(AbstractJavaResourceMethodDispatcher.java:99)
! at org.glassfish.jersey.server.model.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:389)
! at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:347)
! at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:102)
! at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:326)
! at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271)
! at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267)
! at org.glassfish.jersey.internal.Errors.process(Errors.java:315)
! at org.glassfish.jersey.internal.Errors.process(Errors.java:297)
! at org.glassfish.jersey.internal.Errors.process(Errors.java:267)
Anyone can help? Thanks.
cmorfin
(To:cmorfin)
Hi
As indicated here is an update on fixing the issue.
The
WAT9999E
exception is due to the use of t.getMessages().getMessages()
When everything works fine, there will be no message and it will be set to null. hence the call to null.getMessages report the NullPointerException.
To avoid this  call instead toExtendedString()
See attached modified code
Christophe
cmorfin
(To:weli)
Handling this offline, will post outcome when resolved
cmorfin
(To:cmorfin)
Hi
The
WAT9999E
Christophe
