I have an infotable with a list of programs and associated parameters. I want to display the names of the programs in a dropdown widget and use the selected entry from that widget as input for a button widget activated service. However, I am having difficulty finding where the dropdown selection outputs to and how to get the infotable information to a service. How can I retrieve the current selection and its parameters in a service?
Hi @Nate_145 ,
You can use the Selected Row data from the Returned data of the service which is providing/bound to dropdown list widget,
Hi @Nate_145 ,
So I try to grab the selected data from MyThing > GetPropertyValues > ReturnedData > SelectedRows > MyInfotable > Parameters and feed that into a service in the same thing, but from looking at the mashup debug menu I see that data doesn't update when I make a selection in the dropdown. What am I doing wrong that stops me from getting the selected data? Do I need to make a service and if so what kind and where?
Is there an example mashup I could look at to get an idea of how to connect things or a tutorial on how to set the widget up?
You also need to use Selectedrowchange trigger to load the list based on input from first list(dropdown).
example: dropdown 1 has service A generating list. From service A-->Returned data--> selected row will be input for target services and SelectedRowChanged trigger of service A should be used to load Target service.
Learned to make the service to build the infotable. Properties defined infotables don't work for this widget.
For anyone's future reference to get a dropdown widget to function using a static infotable:
- Make a datashape with your needed field definitions
- Create a service that builds an infotable using the snippets "Create infotable from Datashape"
- Populate the infotable using the snippets "Create Infotable Entry from Datashape" or followed by "AddRow(Object)"
- In the mashup you're using the dropdown in, add the service you created in the data panel
- Connect the Returned Data -> All Data to the Data input of the dropdown and define the display field
- Connect the Returned Data -> Selected Row(s) -> variables to any targeted services from the selection in the dropdown
- Use the SelectedRowsChanged event (or a custom event like a button press) to launch the targeted service
