Dropdown mashup select item and after don't include in the same Dropdown
tenegabi
I want to select in a dropdown from a list users list ( I have already do this ) , but after add in the second list the user, I want to make sure in the list I can't add second time same user.
I can do this from Mashup or I need to create a service that compare the users from this two list and create another infotable?
Thank you in advance.
- in mashup you could only add logic to validate same user is not selected. if same user is selected show an error and disable to continue.
- if user should not even be able to get into the state, you need service which creates another infotable without the user.
tenegabi
(To:nmutter)
Hello @nmutter ,
1. I don't want to make a program with an error or another steps.
2. That I want to make it now, a service that compare the list of users and after all take the users that is not selected.
The scope of program is to make fully automatically, not steps for verification.
The easiest solution would be to replace your Dropdown + List with a List Shuttle:
It will ensure uniqueness of the users in the right list.
/ Constantine
uh nice. This widget was not known to me
Might resolve OPs issue
