Dropdown mashup select item and after don't include in the same Dropdown
tenegabi
I want to select in a dropdown from a list users list ( I have already do this ) , but after add in the second list the user, I want to make sure in the list I can't add second time same user.
I can do this from Mashup or I need to create a service that compare the users from this two list and create another infotable?
Thank you in advance.
The easiest solution would be to replace your Dropdown + List with a List Shuttle:
It will ensure uniqueness of the users in the right list.
/ Constantine
- in mashup you could only add logic to validate same user is not selected. if same user is selected show an error and disable to continue.
- if user should not even be able to get into the state, you need service which creates another infotable without the user.
tenegabi
(To:nmutter)
Hello @nmutter ,
1. I don't want to make a program with an error or another steps.
2. That I want to make it now, a service that compare the list of users and after all take the users that is not selected.
The scope of program is to make fully automatically, not steps for verification.
/ Constantine
uh nice. This widget was not known to me
Might resolve OPs issue
