Is it possible to dynamically update content in the page-mashup or master page based on the mashup or widget that is using it ? In other words, I have a help panel in the page-mashup or master page the content for which will depend on the web page I am displaying.
Many fields are bindable, yes. I am a bit confused on what you are asking here. You should be able to retrieve different values from a data table or something based on what you are doing on the mashup. There are also expression and validation widgets to help with this.
Hi Viswesh Palasur,
As per my understanding; you must be using some menu in the master Master to navigate to various Mashup. So, we can use the name of the mashup as input parameter for a service and based on the parameter fetch data for the help panel.
Please share your use-case in more detail if I am missing anything on the requirement.
I hope it helps.
