I'm running the Java EMS and it seems to disconnect from the server after about an hour of running fine. The ems looks to be still running, all I can see in the log that raises any flags is a message "Client has been idle". If I kill and restart the EMS, it connects and communicates fine for another hour or so until it loses communication again.
Any thoughts?
It is probably best you log this as a case on support.ptc.com if you haven't done so yet.
