Hello, does anyone have any experience with error in ERR_SSL_OBSOLETE_CIPHER chrome? (IE works)
I am running CentOs with OpenJDK1.8 and Tomcat 8.
My server.xml looks like this:
<Connector port="8080" protocol="HTTP/1.1"
connectionTimeout="20000"
redirectPort="8443" />
<Connector protocol="org.apache.coyote.http11.Http11NioProtocol"
port="8443" maxThreads="200"
scheme="https" secure="true" SSLEnabled="true"
keystoreFile="/usr/tomcat/conf/.keystore" keystorePass="twadmin"
clientAuth="false" sslProtocol="TLS"/>
Thanks and best regards!
This problem was caused by using OpenJDK, which has problems with crypto. Maybe it is only wrong settings, but when I use Oracle JDK it works good.
Also it is probably better to use Apache or Nginx for frontend, security for these is implemented faster then in Tomcat.
I do not really understand it but this works:
clientAuth="false" sslEnabledProtocols="TLSv1,TLSv1.1,TLSv1.2"
ciphers="TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256, TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA,TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384, TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA,TLS_ECDHE_RSA_WITH_RC4_128_SHA, TLS_RSA_WITH_AES_128_CBC_SHA256,TLS_RSA_WITH_AES_128_CBC_SHA,TLS_RSA_WITH_AES_256_CBC_SHA256, TLS_RSA_WITH_AES_256_CBC_SHA,SSL_RSA_WITH_RC4_128_SHA"/>
