Is it possible to edit entity names once created and saved ? The name options appears to be read only once saved.
Raj
As far as I know it is not possible. However you can duplicate entity. The only field to change will be 'name'. So it will be equal to renaming. But remember that you will have to manually change anything that uses this entity.
