Good time! Can you please tell me if it is possible to create a notification from the service using MailServer? Or just a subscription? There is a service that returns statuses and some more data, it is necessary to send a notification by email according to the status data. Or is it necessary to create a separate property and a subscription for it and embed it in the service?
thanks!
The 'MailServer' Thing has a Service called SendMessage
You can create a service and trigger that from any event to invoke the SendMessage with the necessary information.
That is, it is also normally called from the service? I only called it from subscriptions, so I decided to clarify
