Exported the whole project from one server of TWX and when trying to import in to the another server, getting following error:
@slangley @PaiChung @c_lowy @CarlesColl
Shashi
Hi @slangley ,
This issue has been resolved, it is due to the Dependencies issues with the project, a work around worked for us was, created a new project and assigned all the entities to the new project, exported the project and imported in to another Server. The import was successful.
Shashi.
Hi @pshashipreetham.
What version of ThingWorx are you running? Here's some information in the Help Center for ThingWorx 9.2+ that may be helpful.
As a general rule, you will need to ensure all extensions are installed on the target instance before importing your entities and data. Next, make sure your entities exist before importing the data.
Regards.
--Sharon
Hi @slangley ,
Shashi.
