I am trying to send data from Teltonika RUT955 to ThingWorx server and getting the below error - any idea how to fix this.
[WARN ] 2023-06-20 12:15:54,297: SDK Version: 2.2.1
[WARN ] 2023-06-20 12:15:54,298: TLS Library: OpenSSL
[WARN ] 2023-06-20 12:15:54,299: TLS Library Version: 1.1.1t
[WARN ] 2023-06-20 12:15:54,301: FIPS Capable
[ERROR] 2023-06-20 12:15:54,334: twWs_Create: Error creating BSD socket to be used for the websocket
[ERROR] 2023-06-20 12:15:54,334: twApi_Initialize: Error creating websocket structure, retrying
[ERROR] 2023-06-20 12:15:59,352: twWs_Create: Error creating BSD socket to be used for the websocket
[ERROR] 2023-06-20 12:15:59,353: twApi_Initialize: Error creating websocket structure, retrying
[ERROR] 2023-06-20 12:16:04,362: twWs_Create: Error creating BSD socket to be used for the websocket
[ERROR] 2023-06-20 12:16:04,363: twApi_Initialize: Error creating websocket structure, retrying
[ERROR] 2023-06-20 12:16:09,374: twWs_Create: Error creating BSD socket to be used for the websocket
[ERROR] 2023-06-20 12:16:09,375: twApi_Initialize: Could not connect after 3 attempts
Failed to initialize ThingWorx connection
Failed to send data to ThingWorx
Hi @Akj7579.
While reviewing your post we noticed a couple of things:
Which version of ThingWorx are you running?
Regards.
--Sharon
Hi @Akj7579.
Regards.
--Sharon
Hi @Akj7579.
Did my previous response provide any help in resolving your issue? What is the current status?
Regards.
--Sharon
