I'm trying to run the WSEMS (Microserver-Linux-arm-openssl-5-4-4-434). on my raspberry pi. I have done all the steps from the developers guide.
When i run the wsems i get the following logs:
pi@raspberrypi:~/EMS/microserver $ sudo ./wsems [TRACE] 2018-10-26 12:28:06,32 jsonConfigurator::getString: Key = audit_target, Parent = logger [TRACE] 2018-10-26 12:28:06,32 jsonConfigurator::getValueByType: Key audit_target not found [TRACE] 2018-10-26 12:28:06,32 jsonConfigurator::getString: Key = publish_directory, Parent = logger [TRACE] 2018-10-26 12:28:06,34 jsonConfigurator::getUnsignedInteger: Key = max_file_storage, Parent = logger [TRACE] 2018-10-26 12:28:06,34 jsonConfigurator::getString: Key = publish_level, Parent = logger [TRACE] 2018-10-26 12:28:06,34 jsonConfigurator::getBoolean: Key = auto_flush, Parent = logger [TRACE] 2018-10-26 12:28:06,34 jsonConfigurator::getUnsignedInteger: Key = buffer_size, Parent = logger [TRACE] 2018-10-26 12:28:06,34 jsonConfigurator::getUnsignedInteger: Key = flush_chunk_size, Parent = logger [FORCE] 2018-10-26 12:28:06,34 ./wsems: Initializing EMS .... [FORCE] 2018-10-26 12:28:06,34 main: Using config file /home/pi/EMS/microserver/etc/config.json [INFO ] 2018-10-26 12:28:06,34 ./wsems: Creating the WsEms proxy. [TRACE] 2018-10-26 12:28:06,34 DutyCycle::DutyCycle: Constructor called [DEBUG] 2018-10-26 12:28:06,34 DutyCycle::calculateDutyCycleTimePeriods: m_ConnectPeriod: 60000 [DEBUG] 2018-10-26 12:28:06,34 DutyCycle::calculateDutyCycleTimePeriods: m_DisconnectPeriod: 0 [TRACE] 2018-10-26 12:28:06,34 wsEmsProxy::wsEmsProxy: Constructor called [INFO ] 2018-10-26 12:28:06,34 ./wsems: Starting HTTP Server. [TRACE] 2018-10-26 12:28:06,34 jsonConfigurator::getInteger: Key = port, Parent = http_server [TRACE] 2018-10-26 12:28:06,34 jsonConfigurator::getValueByType: Key port not found [TRACE] 2018-10-26 12:28:06,34 jsonConfigurator::getString: Key = host, Parent = http_server [TRACE] 2018-10-26 12:28:06,34 jsonConfigurator::getValueByType: Key host not found [TRACE] 2018-10-26 12:28:06,34 jsonConfigurator::getInteger: Key = ports_to_try, Parent = http_server [TRACE] 2018-10-26 12:28:06,34 jsonConfigurator::getValueByType: Key ports_to_try not found [TRACE] 2018-10-26 12:28:06,34 jsonConfigurator::getInteger: Key = max_clients, Parent = http_server [TRACE] 2018-10-26 12:28:06,34 jsonConfigurator::getValueByType: Key max_clients not found [TRACE] 2018-10-26 12:28:06,34 jsonConfigurator::getBoolean: Key = enable_csrf_tokens, Parent = http_server [TRACE] 2018-10-26 12:28:06,34 jsonConfigurator::getValueByType: Key enable_csrf_tokens not found [TRACE] 2018-10-26 12:28:06,35 jsonConfigurator::getInteger: Key = csrf_token_rotation_period, Parent = http_server [TRACE] 2018-10-26 12:28:06,35 jsonConfigurator::getValueByType: Key csrf_token_rotation_period not found [TRACE] 2018-10-26 12:28:06,35 jsonConfigurator::getBoolean: Key = use_default_certificate, Parent = http_server [INFO ] 2018-10-26 12:28:06,35 Main: Using built-in certificate for HTTP Server [TRACE] 2018-10-26 12:28:06,35 jsonConfigurator::getBoolean: Key = ssl, Parent = http_server [WARN ] 2018-10-26 12:28:06,35 Main: Encryption is disabled on HTTP Server. [TRACE] 2018-10-26 12:28:06,35 jsonConfigurator::getString: Key = certificate, Parent = http_server [TRACE] 2018-10-26 12:28:06,35 jsonConfigurator::getValueByType: Key certificate not found [TRACE] 2018-10-26 12:28:06,35 jsonConfigurator::getString: Key = private_key, Parent = http_server [TRACE] 2018-10-26 12:28:06,35 jsonConfigurator::getValueByType: Key private_key not found [TRACE] 2018-10-26 12:28:06,35 jsonConfigurator::getString: Key = enable_csrf_tokens, Parent = http_server [TRACE] 2018-10-26 12:28:06,35 jsonConfigurator::getValueByType: Key enable_csrf_tokens not found [TRACE] 2018-10-26 12:28:06,35 jsonConfigurator::getBoolean: Key = validate, Parent = certificates [TRACE] 2018-10-26 12:28:06,35 jsonConfigurator::getBoolean: Key = authenticate, Parent = http_server [WARN ] 2018-10-26 12:28:06,35 Main: Authentication is disabled on the HTTP Server. [TRACE] 2018-10-26 12:28:06,35 jsonConfigurator::getInteger: Key = content_read_timeout, Parent = http_server [TRACE] 2018-10-26 12:28:06,35 jsonConfigurator::getValueByType: Key content_read_timeout not found [INFO ] 2018-10-26 12:28:06,35 ./wsems: Initializing the ThingWorx REST interface. [TRACE] 2018-10-26 12:28:06,35 wsEmsProxy::initialize: Method entered [FORCE] 2018-10-26 12:28:06,35 httpServer: [TRACE] 2018-10-26 12:28:06,35 jsonConfigurator::getString: Key = level, Parent = logger [TRACE] 2018-10-26 12:28:06,36 jsonConfigurator::getBoolean: Key = verbose, Parent = ws_connection [TRACE] 2018-10-26 12:28:06,36 jsonConfigurator::getBoolean: Key = enabled, Parent = fips [INFO ] 2018-10-26 12:28:06,36 wsEmsProxy::initialize: FIPS is disabled. [TRACE] 2018-10-26 12:28:06,36 jsonConfigurator::getString: Key = encryption, Parent = ws_connection [INFO ] 2018-10-26 12:28:06,36 wsEmsProxy::initialize: Encryption is disabled on Web Socket connection.
[TRACE] 2018-10-26 12:28:06,36 jsonConfigurator::getString: Key = appkey, Parent = [TRACE] 2018-10-26 12:28:06,36 jsonConfigurator::getString: Key = resource, Parent = [TRACE] 2018-10-26 12:28:06,36 jsonConfigurator::getValueByType: Key resource not found [TRACE] 2018-10-26 12:28:06,36 jsonConfigurator::getInteger: Key = port, Parent = proxy [TRACE] 2018-10-26 12:28:06,36 jsonConfigurator::getValueByType: Parent proxy not found [TRACE] 2018-10-26 12:28:06,37 jsonConfigurator::getString: Key = host, Parent = proxy [TRACE] 2018-10-26 12:28:06,37 jsonConfigurator::getValueByType: Parent proxy not found [TRACE] 2018-10-26 12:28:06,37 jsonConfigurator::getString: Key = user, Parent = proxy [TRACE] 2018-10-26 12:28:06,37 jsonConfigurator::getValueByType: Parent proxy not found [TRACE] 2018-10-26 12:28:06,37 jsonConfigurator::getString: Key = password, Parent = proxy [TRACE] 2018-10-26 12:28:06,37 jsonConfigurator::getValueByType: Parent proxy not found [TRACE] 2018-10-26 12:28:06,37 jsonConfigurator::getUnsignedInteger: Key = socket_read_timeout, Parent = ws_connection [TRACE] 2018-10-26 12:28:06,37 jsonConfigurator::getValueByType: Key socket_read_timeout not found [TRACE] 2018-10-26 12:28:06,37 jsonConfigurator::getUnsignedInteger: Key = frame_read_timeout, Parent = ws_connection [TRACE] 2018-10-26 12:28:06,37 jsonConfigurator::getValueByType: Key frame_read_timeout not found [TRACE] 2018-10-26 12:28:06,37 jsonConfigurator::getUnsignedInteger: Key = ssl_read_timeout, Parent = ws_connection [TRACE] 2018-10-26 12:28:06,37 jsonConfigurator::getValueByType: Key ssl_read_timeout not found [TRACE] 2018-10-26 12:28:06,37 jsonConfigurator::getUnsignedInteger: Key = msg_timeout, Parent = ws_connection [TRACE] 2018-10-26 12:28:06,37 jsonConfigurator::getValueByType: Key msg_timeout not found [TRACE] 2018-10-26 12:28:06,37 jsonConfigurator::getUnsignedInteger: Key = ping_rate, Parent = ws_connection [TRACE] 2018-10-26 12:28:06,37 jsonConfigurator::getValueByType: Key ping_rate not found [TRACE] 2018-10-26 12:28:06,37 jsonConfigurator::getUnsignedInteger: Key = pingpong_timeout, Parent = ws_connection [TRACE] 2018-10-26 12:28:06,37 jsonConfigurator::getValueByType: Key pingpong_timeout not found [TRACE] 2018-10-26 12:28:06,37 jsonConfigurator::getUnsignedInteger: Key = max_threads, Parent = ws_connection [TRACE] 2018-10-26 12:28:06,37 jsonConfigurator::getValueByType: Key max_threads not found [TRACE] 2018-10-26 12:28:06,37 jsonConfigurator::getUnsignedInteger: Key = max_msg_size, Parent = ws_connection [TRACE] 2018-10-26 12:28:06,37 jsonConfigurator::getValueByType: Key max_msg_size not found [TRACE] 2018-10-26 12:28:06,37 jsonConfigurator::getUnsignedInteger: Key = max_messages, Parent = ws_connection [TRACE] 2018-10-26 12:28:06,37 jsonConfigurator::getValueByType: Key max_messages not found [TRACE] 2018-10-26 12:28:06,37 jsonConfigurator::getBoolean: Key = verbose, Parent = ws_connection [TRACE] 2018-10-26 12:28:06,37 jsonConfigurator::getBoolean: Key = connect_on_demand, Parent = ws_connection [TRACE] 2018-10-26 12:28:06,37 jsonConfigurator::getValueByType: Key connect_on_demand not found [TRACE] 2018-10-26 12:28:06,37 jsonConfigurator::getUnsignedInteger: Key = max_connect_delay, Parent = ws_connection [TRACE] 2018-10-26 12:28:06,37 jsonConfigurator::getValueByType: Key max_connect_delay not found [TRACE] 2018-10-26 12:28:06,38 jsonConfigurator::getUnsignedInteger: Key = message_idle_time, Parent = ws_connection [TRACE] 2018-10-26 12:28:06,38 jsonConfigurator::getValueByType: Key message_idle_time not found [TRACE] 2018-10-26 12:28:06,38 jsonConfigurator::getUnsignedInteger: Key = connect_timeout, Parent = ws_connection [DEBUG] 2018-10-26 12:28:06,38 httpServer: http server bound to port=8000. [TRACE] 2018-10-26 12:28:06,38 jsonConfigurator::getValueByType: Key connect_timeout not found [TRACE] 2018-10-26 12:28:06,38 jsonConfigurator::getUnsignedInteger: Key = connect_retry_interval, Parent = ws_connection [TRACE] 2018-10-26 12:28:06,38 jsonConfigurator::getValueByType: Key connect_retry_interval not found [TRACE] 2018-10-26 12:28:06,38 jsonConfigurator::getInteger: Key = connect_retries, Parent = ws_connection [TRACE] 2018-10-26 12:28:06,38 jsonConfigurator::getValueByType: Key connect_retries not found [TRACE] 2018-10-26 12:28:06,38 jsonConfigurator::getUnsignedInteger: Key = connect_period, Parent = duty_cycle [TRACE] 2018-10-26 12:28:06,38 jsonConfigurator::getValueByType: Parent duty_cycle not found [TRACE] 2018-10-26 12:28:06,38 jsonConfigurator::getUnsignedInteger: Key = duty_cycle, Parent = duty_cycle [TRACE] 2018-10-26 12:28:06,38 jsonConfigurator::getValueByType: Parent duty_cycle not found [TRACE] 2018-10-26 12:28:06,38 jsonConfigurator::getUnsignedInteger: Key = delay_duty_cycle, Parent = duty_cycle [TRACE] 2018-10-26 12:28:06,38 jsonConfigurator::getValueByType: Parent duty_cycle not found [DEBUG] 2018-10-26 12:28:06,38 wsEmsProxy::initialize: [DEBUG] 2018-10-26 12:28:06,38 wsEmsProxy::initialize: EMS Duty Cycle configuration from config.json: [DEBUG] 2018-10-26 12:28:06,38 wsEmsProxy::initialize: m_DutyCycle.setDutyCyclePeriod: 60000
[DEBUG] 2018-10-26 12:28:06,38 wsEmsProxy::initialize: m_DutyCycle.setDutyCyclePercent: 100 [DEBUG] 2018-10-26 12:28:06,38 wsEmsProxy::initialize: m_DutyCycle.setConnectTimeout: 10000 [DEBUG] 2018-10-26 12:28:06,38 wsEmsProxy::initialize: m_DutyCycle.setConnectRetries: -1 [DEBUG] 2018-10-26 12:28:06,38 wsEmsProxy::initialize: m_DutyCycle.setDelayDutyCycle: 60000 [DEBUG] 2018-10-26 12:28:06,38 wsEmsProxy::initialize: [TRACE] 2018-10-26 12:28:06,38 jsonConfigurator::getBoolean: Key = enabled, Parent = offline_msg_store [TRACE] 2018-10-26 12:28:06,38 jsonConfigurator::getValueByType: Parent offline_msg_store not found [TRACE] 2018-10-26 12:28:06,38 jsonConfigurator::getString: Key = directory, Parent = offline_msg_store [TRACE] 2018-10-26 12:28:06,38 jsonConfigurator::getValueByType: Parent offline_msg_store not found [TRACE] 2018-10-26 12:28:06,38 jsonConfigurator::getUnsignedInteger: Key = max_size, Parent = offline_msg_store [TRACE] 2018-10-26 12:28:06,38 jsonConfigurator::getValueByType: Parent offline_msg_store not found [TRACE] 2018-10-26 12:28:06,38 jsonConfigurator::getUnsignedInteger: Key = message_chunk_size, Parent = ws_connection [WARN ] 2018-10-26 17:58:06,39 SDK: SDK Version: 2.1.5 [WARN ] 2018-10-26 17:58:06,39 SDK: TLS Library: OpenSSL [WARN ] 2018-10-26 17:58:06,39 SDK: TW_SSL_VERSION: Error tls runtime version: OpenSSL 1.0.2l 25 May 2017, does not match compiled version: OpenSSL 1.0.2l-fips 25 May 2017 [WARN ] 2018-10-26 17:58:06,39 SDK: TLS Library Version: 1.0.2l [WARN ] 2018-10-26 17:58:06,39 SDK: FIPS Capable [ERROR] 2018-10-26 17:58:06,39 SDK: twApi_Initialize: Invalid parameter found [ERROR] 2018-10-26 12:28:06,39 WsProxy::initialize: Unable to initialize twApi singleton [ERROR] 2018-10-26 12:28:06,39 Main: Could initialize the wsEmsProxy [FORCE] 2018-10-26 12:28:06,39 Main: Exiting.... [DEBUG] 2018-10-26 12:28:11,43 jsonConfigurator::~jsonConfigurator: Deleting JSON object [TRACE] 2018-10-26 12:28:11,44 wsEmsProxy::~wsEmsProxy: Destructor called [TRACE] 2018-10-26 12:28:11,44 WsProxy::~WsProxy: Deleting Thing binding list [TRACE] 2018-10-26 12:28:11,44 DutyCycle::~DutyCycle: Destructor called
This is my config.json:
"ws_servers": [
"host": "***********",
"port": 80
"appKey": "AES:**************",
"http_server": {
"use_default_certificate": true,
"ssl": false,
"authenticate": false
"ws_connection": {
"encryption": "none",
"verbose":true,
"message_chunk_size": 8192
"fips": {
"enabled": false
"logger": {
"level":"TRACE",
"publish_directory":"/home/pi/EMS/microserver/logs",
"publish_level":"TRACE",
"max_file_storage":2000000,
"auto_flush":true,
"flush_chunk_size": 16384,
"buffer_size" : 4096
"auto_bind": [
"name": "Test_WSEMS",
"port": 8001,
"timeout": 30000,
"protocol": "http",
"gateway": false
"certificates": {
"validate": false
It would be great if someone could help out with this.
Hi @vvmonty,
I think your issue is you are using the ARM release of the EMS instead of the ARM-HF release. Try using the ARM-HF release.
-- Alex
Hi @vvmonty,
-- Alex
