Dear Team,
I have made my thing property as logged for to use value stream.
On refreshing on properties values are changing. But no value get logged.
In application log getting error : Error notifying things of propertyBinding changes on activate: TestThing property Temperature1
Just a dumb question, did you set a ValueStream on the Thing?
Did you ever get this figured out? I have the same application log error and am wondering what it means.
This is related to a Local or Remote Binding, when you do a property write this property write propagates to the Local/RemoteBinding and if it fails to write neither it writes on the Thing's property.
Did anybody have this problem too? I am having there error in Kepware console. Looks like the properties are being updated but these messages are overflowing logs. Here is the message I get:
Error notifying things of propertyBinding changes on activate: Asset_Prepac property prepac_Total_B
Any Idea?
Ewerton Moreira, check out the following link. I am experiencing similar problem when trying to bind properties locally. No idea what's going on.
Did you have any luck getting this figured out?
