Error using Resources["EntityServices"].CloneThing(params)
fkuong
3-Visitor
I have a simple service to clone an existing thing. I use Resources["EntityServices"].CloneThing and I got the following error:
JavaException: java.lang.Exception: Unable To Convert From org.json.JSONObject to INFOTABLE
When I duplicate the Thing manually in the Composer there is not problem I can duplicate the thing.
Could you please give some advice?
Freddy
3 REPLIES 3
CharlesJi
(To:fkuong)
 Can you please check the schema of params?
 It should be like the following:
var params = {
	name: "clone_target_thing" /* STRING */,
	description: "Description of clone" /* STRING */,
	sourceThingName: "clone_source_thing" /* THINGNAME */,
	tags: [{
    	"vocabulary" : "Test",
        "vocabularyTerm" : "CloneThingSnippet"
    }] /* TAGS */
Resources["EntityServices"].CloneThing(params);
Hi Charles,
My schema for params is correct, in my case description and Tags are undefined.
Freddy
CharlesJi
(To:fkuong)
Hi, Freddy
Could you please send me the full code of your service, both the ApplicationLog.log and ScriptLog.log when you can reproduce the error message?
* The logs are located in <Thingworx Path>\ThingworxStorage\logs
Charles
