Error when following "ThingWorx Java SDK Setup Guide"
llevan
3-Newcomer
I've tried to following the 'ThingWorx Java SDK Setup Guide' but i'm facing several problem.
First of all, there is no link to the Java SDK. I went to the marketplace to download it. Then I follow instruction until the "Composer Entities Setup" step. I searched for ThingWorxEntitiesExport.xml but only ExampleExport.xml so i tried to import it and facing "Error importing: error, Import Failed: Validation Failure: Thing FirstFloorSteamSensor Had An Invalid DataShape [SteamSensorReadingsPlus] assigned to the result type in service [GetSteamSensorReadings]".
Does someone know how to fix it ?
Thank you.
Hello Laurent,
It looks like the full zip drive is not included in a link from the setup guide. I've attached the link to the source code and the entities file.
Java SDK - Google Drive
9 REPLIES 9
rupadhyay
(To:llevan)
Laurent Le Van
I am just seeing you are doing it right., and I confirm that there is no ThingWorxEntitiesExport.xml but only ExampleExport.xml which is not in line with  instructions given in Guide .
I have a work around , give me some time , let me test i first and I will let you know then.
Hello Laurent,
Thank you for the link !
rupadhyay
(To:llevan)
Laurent , you just need to download the correct Java SDK Zip file from the link Jason mentioned , and there you will find ThingWorxEntitiesExport.xml and it willl be imported without error and then you need to continue following the same steps.
llevan
3-Newcomer
(To:rupadhyay)
Ok thank you it's work now !
mludyga
2-Explorer
(To:llevan)
Hey guys,
I have the same problem as Laurent Le Van. I have only the ExampleExport.xml and even if I download from the link that Jason Johnson posted, I dont get the ThingWorxEntitiesExport.xml file.
rupadhyay
(To:mludyga)
Please download the zip file from Java SDK - Google Drive   .
You will find the ThingWorxEntitiesExport.xml file. downloaded from here.
Let me know if it helps.
mludyga
2-Explorer
(To:rupadhyay)
it works now, thank you.
