getting error SDK: Error intializing socket connection. Err = -1 while connecting EMS to thingworx
Hi balkrishna, have you re-checked the configuration for the EMS? Are you configuring for the first time? Could you share which for which OS are you configuring the EMS and ThingWorx server version. How is the encryption setup for the EMS and on the ThingWorx server?
Hi sushant,i'm configuring EMS for windows and thingworx 7.I have set encryption as none.
Can you send your whole EMS config file (you can retract the appKey, if you'd like)?
Here is a copy of a working EMS config with file transfer and tunneling to a localhost instance with no encryption and an auto bind to a thing named StandardRemoteThing, the appKey, host, and potentially the virtual directory would need to be updated:
"ws_servers": [{
"host": "localhost",
"port": 80
"appKey": "92d68c74-4bf3-42c8-ab7c-0cb602d11873",
"ws_connection": {
"encryption": "none",
"verbose": true
"logger": {
"level": "TRACE",
"publish_directory":"/_tw_logs/",
"publish_level":"TRACE",
"max_file_storage":2000000,
"auto_flush":true
"certificates": {
"validate": false,
"allow_self_signed": true
"auto_bind": [{
"name": "StandardRemoteThing",
"gateway": false
"tunnel": {
"buffer_size": 8192,
"read_timeout": 10,
"idle_timeout": 300000,
"max_concurrent": 4
"file": {
"buffer_size": 128000,
"max_file_size": 8000000000,
"virtual_dirs": [
{"tw": "c:\\filestest"}
You may validate your json at JSONLint - The JSON Validator.
Have you renamed your config file to config.json? What is the port number you are using? If no proxy is set up, you should be using the same as in when accessing the composer through the browser (e.g, 80, 8080, .. )
