I am trying to build a simple application with the Edge Microserver in order to update the properties of a thing in the Thingworx core. I am using a put request in Python in order to write the data. When running the program I see an error on the Microserver as follows:
twInfoTable_ToJson: NULL of bad infotable
Does anyone know what this error means or how I can fix it?
Thanks!
Currently my python code is this:
#!/usr/bin/python
import requests
import sys
import json
import logging
logging.basicConfig()
logging.getLogger().setLevel(logging.DEBUG)
requests_log = logging.getLogger("requests.packages.urllib3")
requests_log.setLevel(logging.DEBUG)
requests_log.propagate = True
appKey = 'xxxxxxxxx'
Webhost = "http://localhost:8000/Thingworx/Things/RT2/Properties/*"
payload = [{'Color': 'green', 'Size': 108}]
headers = { 'Content-Type': 'application/json', 'appKey': appKey }
response = requests.put(Webhost, headers=headers, json=payload, verify=True)
print(response)
The configuration json for the edge microserver is this:
"ws_servers": [{
"host": "<host_ip>",
"port": 80
"appKey": "xxxxxxxx",
"ws_connection": {
"encryption": "none"
"certificates": {
"validate": false,
"allow_self_signed": true
"http_server": {
"host" : "localhost",
"port" : 8000,
"ssl" : false,
"authenticate" : false
Hi Connor,
That error points to issues converting a native InfoTable into JSON data, but it's difficult to really say what's going on without more context. Can you try setting your log level to 'TRACE' in config.json and posting a bit of the log where you see the error.
