I got this error every time I want to create signals or profiles. :
[context: com.thingworx.webservices.context.HttpExecutionContext@6dbd4d1d][message: Execution error in service script [CreateSignalAMS] :: JavaException: com.thingworx.common.exceptions.GenericHTTPException: Got error code [502] from service [SignalsMicroserver] method [CreateJob] (CreateSignalAMS#69)]
Sorry to hear that restarting the applciation did not resolve the issue.
With the ThingWorx Trial Edition (TTE) there is no solution for microservice corruption if a restart does not resolve the issue.
I would recommend un-installing TTE, removing the install directory, then re-install TTE.
Neel
Thank you for your Post.
I have some clarifying questions for you:
I look forward to your response,
Neel
Sorry I marked the post solved by mistake
Neel
