Execution Error in service script
magrawal
2-Explorer
I have service which receives a string as input and result number as output. I have tested service is working as expected.
I have binded that service with value display widget and input to service through mashup parameter. When running mashup I am getting error: "Execution error in service script [Thing serviceName] : TypeError: Cannot call method "serviceName" of null (serviceName#2)"
2 REPLIES 2
posipova
20-Turquoise
(To:magrawal)
Are you logged in as Administrator?  Is the parameter type matching your service value type?
Looks like the logged-in user does not have access (visibility) to the entity on which the service is defined.
