I have a Thing and valuestream associated to that. Have made properties of that thing logged and persistent so that I can use valuestream for time series. I'm able to get the same in a mashup.
If I wanted to write a service which will perform the same function as an export widget in a mashup, I would be able to invoke service every x mins to export the property history to csv
Thanks in advance
Or else you can try using the service "WriteCSVFile" from available snippet .It is like this -
var params = {
path: undefined /* STRING */,
data: undefined /* INFOTABLE */,
fileRepository: undefined /* THINGNAME */,
withHeader: undefined /* BOOLEAN */
// no return
Resources["CSVParserFunctions"].WriteCSVFile(params);
It takes data as an infotable which will be coming from the "QueryPropertyHistory" so you can pass that infotable to this service and write this to CSV in repository .
Hello, I think you could use the service in Data Export Extension, the entity it includes have service to help infotable exported as CSV file.
var params = {
// no return
Thank you. This worked
Arvind
