Exporting/importing of data from/to thingworx
rkandasamy
7-Bedrock
Hi Team.
I do export of multiple datatables from thingworx and import into another thingworx system.
While submitting for export, I get a pop up giving me the task Id. Where do I find if that particular task is successful?
In which log level, i can see the status of this task id.
It would be helpful if you provide the answer with the screen shots.
1 REPLY 1
ttielebein
(To:rkandasamy)
The task status will appear in the Application log, located under Monitoring > Application in the navigation bar at the top-right corner of ThingWorx Composer. The Application log looks like this:
Hope this helps!
