I've noticed that Import/Export -> Export -> Source Control Entities produces nicely formatted XML files, but More -> Export for Source Control does not. Is this the intended behavior or a bug? The formatted XML is much easier to diff between revisions, and it'd be nice to be able to get it from both XML generators.
This is a bug in 6.5,, which will be fixed in 6.6.
Excellent, thank you!
