FAIL - Application at context path [/Thingworx] could not be started
SOLVED
Re: FAIL - Application at context path [/Thingworx] could not be started
Hi Polina Osipova​ I was able to successfully install Thingworx 8.0 applying the solution you provided.
I did a fresh installation and the significant correction was reinstalling Tomcat from Tomcat 8.5 32 bit to Tomcat 8.0 64 bit.
Kudos!
Hi Angelica,
If i try to install Thingworx 8.1 (Trail) version. How can i get a Activation ID?
I am facing an issue like "FAIL - Application at context path /Thingworx could not be started"
How to resolve this issue?
Sathishkumar C.
I am also facing the same issue and that logs folder is empty.
Please help me out.
