Hi Community,
I have installed Integration Runtime on my system and trying to connect to windchill using custom Integration connector. I have configured Integration Runtime following ptc support "https://support.ptc.com/help/thingworx_hc/thingworx_8_hc/en/index.html#page/ThingWorx/Help/Composer/IntegrationConnectors/InitialSetupofIntegrationRuntimeServiceforIntegrationConnectors.html#".
Post this I created custom Odata connector and provided fixed authentication. But connection fails while executing "ValidateConnection" service. Also error log shows initialization failed error.
Attaching Screenshot of steps I followed to configure Integration Runtime and creating custom odata connector. Kindly help.
Sid
Hi Sid,
The error you listed in the doc I don't think is relevant. Can you attach ThingWorx Script and Error logs and Integration Runtime log?
Otherwise, if you prefer you can open support PTC case instead.
Thanks!
--Marek
