I have failed to import a database Thing, that is exported from a DEV system, into a QA system. That was failed because of password fields in the XML exported file. What is the best way to migrate changes in a database Thing from a system to another system? Both systems are running the same version 7.4.19-b262
Any suggestion would be greatly appreciated!
My Bests,
Hung Tran
Hi @vangne
The suggested solution "binary mode" does not work cause that will lead to lose the existing configuration of these Things on the target system. I've written a small tool that help me migrate changes without losing any configuration.
Sincerely,
Hung Tran
Hi @vangne
The error is 406 Not Acceptable.
2019-08-27 03:20:20.484-0500 [L: ERROR] [O: E.c.t.w.Importer] [I: ] [U: tranh] [S: ] [T: http-nio-192.168.230.139-443-exec-32] [message: Conversion Error on Field password : Unable To Convert From com.sun.org.apache.xerces.internal.dom.DeferredElementNSImpl to PASSWORD]
2019-08-27 03:20:20.484-0500 [L: ERROR] [O: E.c.t.w.Importer] [I: ] [U: tranh] [S: ] [T: http-nio-192.168.230.139-443-exec-32] [message: Conversion Error on Field password : Unable To Convert From com.sun.org.apache.xerces.internal.dom.DeferredElementNSImpl to PASSWORD] java.lang.Exception: Conversion Error on Field password : Unable To Convert From com.sun.org.apache.xerces.internal.dom.DeferredElementNSImpl to PASSWORD at com.thingworx.types.collections.ValueCollection.fromXMLTypedImport(ValueCollection.java:583) at com.thingworx.types.collections.ValueCollectionList.fromXMLTypedImport(ValueCollectionList.java:315) at com.thingworx.types.ConfigurationTable.fromXMLImport(ConfigurationTable.java:201) at com.thingworx.types.collections.ConfigurationTableCollection.fromXMLImport(ConfigurationTableCollection.java:362) at com.thingworx.entities.utils.EntitySerializationUtilities.readConfigurationDataFromXMLImport(EntitySerializationUtilities.java:79) at com.thingworx.entities.RootEntity.readRootEntityFromXMLGeneric(RootEntity.java:3827) at com.thingworx.entities.RootEntity.readRootEntityFromXMLImport(RootEntity.java:3841) at com.thingworx.things.Thing.fromXMLImport(Thing.java:8889) at com.thingworx.system.managers.ThingManager.fromXMLImport(ThingManager.java:129) at com.thingworx.entities.collections.RootEntityCollection.fromXML(RootEntityCollection.java:454) at com.thingworx.contentmanagement.XmlEntityUnmarshaller.getRootEntityCollectionByName(XmlEntityUnmarshaller.java:52) at com.thingworx.contentmanagement.Import.parseImportDocument(Import.java:42) at com.thingworx.contentmanagement.Import.parseImportDocument(Import.java:23) at com.thingworx.webservices.Importer.processImport(Importer.java:311) at com.thingworx.webservices.Importer.importFromAttachment(Importer.java:195) at com.thingworx.webservices.Importer.service(Importer.java:153) at javax.servlet.http.HttpServlet.service(HttpServlet.java:729) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:292) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:207) at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:240) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:207) at com.thingworx.security.contenttype.ContentTypeFilter.doFilter(ContentTypeFilter.java:109) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:240) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:207) at com.thingworx.security.filter.ValidationFilter.doFilter(ValidationFilter.java:22) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:240) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:207) at com.thingworx.security.authentication.AuthenticationFilter.propagateRequest(AuthenticationFilter.java:479) at com.thingworx.security.authentication.AuthenticationFilter.doFilter(AuthenticationFilter.java:172) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:240) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:207) at org.tuckey.web.filters.urlrewrite.RuleChain.handleRewrite(RuleChain.java:176) at org.tuckey.web.filters.urlrewrite.RuleChain.doRules(RuleChain.java:145) at org.tuckey.web.filters.urlrewrite.UrlRewriter.processRequest(UrlRewriter.java:92) at org.tuckey.web.filters.urlrewrite.UrlRewriteFilter.doFilter(UrlRewriteFilter.java:389) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:240) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:207) at com.thingworx.security.filter.ClickjackFilter.doFilter(ClickjackFilter.java:188) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:240) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:207) at com.thingworx.security.filter.ProhibitIfNotLeaderFilter.doFilter(ProhibitIfNotLeaderFilter.java:120) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:240) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:207) at com.thingworx.security.filter.HttpResponseHeadersFilter.doFilter(HttpResponseHeadersFilter.java:173) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:240) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:207) at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:212) at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:94) at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:504) at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:141) at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:79) at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:620) at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:88) at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:502) at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1132) at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:684) at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1533) at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.run(NioEndpoint.java:1489) at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61) at java.lang.Thread.run(Unknown Source)
I tried to export the same database thing from both systems into XML files, and compare, the different section is password tag. I did manually merge changes without password tag, and it works. However, that way is a pain.
My Bests,
Hung Tran
Hi @vangne
Thank you, however the configuration setup is lost. Is there any way that lets me migrate changes without losing of configuration setup? Those systems have a different configuration setup on that database Thing.
My Bests,
Hung Tran
If you were able to resolve your issue, please post it here and mark it as the Accepted Solution for the benefit of others on the community. If you are still experiencing issues, please check below feedback.
Have you had an opportunity to take a look at these articles?
1. https://www.ptc.com/en/support/article?n=CS297147
2. https://www.ptc.com/en/support/article?n=CS285629
If this does not resolve your issue, then please open a support case for further investigation.
Vibhuti
Hi @vangne
Sincerely,
Hung Tran
