I am currently following the SteamSensor example for Thingworx and have hit a problem. I was successfully able to connect to a local instance of Thingworx as well as one located on my network. However, when I try to connect to an external server, the connection seems to time out.
I am currently working with the C SDK, and am unable to tell if this is a problem with the server or the agent. Below I have posted the output from the SteamSensor program. I should note that the version of the Thingworx instance is 6.0.2, and that I am trying to connect on port 443. Any ideas on the cause of this issue would be appreciated.
Thank You.
[FORCE] 2016-06-07 08:18:15,354: Starting up
[DEBUG] 2016-06-07 08:18:15,355: twWs_Create: Initializing Websocket Client for
“<PTC Hosted Thingworx instance>”
[DEBUG] 2016-06-07 08:18:15,355: twTlsClient_Create: Initializing TLS Client
[DEBUG] 2016-06-07 08:18:15,456: twApi_Initialize: Websocket Established after 0
tries
[DEBUG] 2016-06-07 08:18:15,457: subscribedPropsMgr_Initialize: Initializing sub
scribed properties manager
[DEBUG] 2016-06-07 08:18:22,129: twTlsClient_Reconnect: Re-establishing SSL cont
ext
[DEBUG] 2016-06-07 08:18:22,135: twTlsClient_Connect: Connecting to server
[ERROR] 2016-06-07 08:18:32,137: twWs_Connect: Error trying to connect
[DEBUG] 2016-06-07 08:18:32,137: twTlsClient_Reconnect: Re-establishing SSL cont
ext
[DEBUG] 2016-06-07 08:18:32,156: twTlsClient_Connect: Connecting to server
[DEBUG] 2016-06-07 08:18:37,157: twTlsClient_Reconnect: Re-establishing SSL cont
ext
[DEBUG] 2016-06-07 08:18:37,164: twTlsClient_Connect: Connecting to server
[ERROR] 2016-06-07 08:18:47,173: twWs_Connect: Error trying to connect
[DEBUG] 2016-06-07 08:18:47,173: twTlsClient_Reconnect: Re-establishing SSL cont
ext
[DEBUG] 2016-06-07 08:18:47,192: twTlsClient_Connect: Connecting to server
[DEBUG] 2016-06-07 08:18:52,198: twTlsClient_Reconnect: Re-establishing SSL cont
ext
[DEBUG] 2016-06-07 08:18:52,209: twTlsClient_Connect: Connecting to server
[ERROR] 2016-06-07 08:19:02,212: twWs_Connect: Error trying to connect
[DEBUG] 2016-06-07 08:19:02,212: twTlsClient_Reconnect: Re-establishing SSL cont
ext
[DEBUG] 2016-06-07 08:19:02,222: twTlsClient_Connect: Connecting to server
[ERROR] 2016-06-07 08:19:07,224: twApi_Connect: Max number of connect retries: 3
, has been reached
[ERROR] 2016-06-07 08:19:07,224: main: Server connection failed after 3 attempts
. Error Code: 201
Andrew, can you ping the server? Are there any firewalls on your side or the external server side?
I can successfully ping the server. Our firewall doesn't appear to be blocking the connection, however I am unsure how to test the PTC hosted server's firewall. Is it possible I have something disabled in the example that needs to be enabled for connecting to external servers?
Can you post your connection Uri?
Do you need the full string? Or will this be enough? Sorry for the delayed response.
**********************************************.com:443//Thingworx/WS
I wanted to check if it was formatted correctly, as in wss://server:443/Thingworx/WS
Sorry about that. The beginning of the URI I posted did not have a "wss://" at the beginning. In other words, it started with the server's name, giving it the format off, "server:443//Thingworx/WS". Note, I pulled my URI from the debug output shown above in the spot where “<PTC Hosted Thingworx instance>” is now. When I define host in main.c do I need to put "wss://server" instead of just the server's name?
Yes, you would need to have wss in the beginning, as this makes it a websocket secure connection. For a non secure (or non ssl) port, the Uri usually reads as ws://server:80/Thingworx/WS
Alright, I added on "wss://" so now...
host = wss://ServerName
port = 443
TW_URI = /Thingworx/WS
TW_APP_KEY = A key created on the external server
Now I'm getting a new error that says, "twApi_Initialize: Error creating websocket structure, retrying". This will fail three times and then the program will exit saying "Error initializing the API". Any ideas on how to correct this issue?
Andrew, sorry I didn't realize the flags were broken up. Have you looked at the Edge Help Center? Click here for information regarding configuring the API Singleton.
Thank you for the link. I went through the documentation today, but I don't quite see the problem. Just to double check everything, I downloaded a fresh copy of the C SDK and went through the tutorial outlined here. I also checked that there was no proxy server involved in the connection. Unfortunately, I am still getting the same error.
[ERROR] 2016-06-10 15:37:44,462: twWs_Create: Error creating BSD socket to be used for the websocket
[ERROR] 2016-06-10 15:37:44,462: twApi_Initialize: Error creating websocket structure, retrying
Is there anything that I have to do on the Thingworx instance or Axeda Server to allow the connection? or have I possibly missed steps not included in the tutorial?
Thank you for your help so far.
That's interesting, I've come across BSD socket errors if there is a proxy (mainly, reverse proxy) involved, or if there is a firewall or something similar that does not support websockets. Is there a chance you can connect to a different server that is out of your current network? If you have it connected to a local instance, then you're pretty much set; other than changing the basic host/port and appKey, you shouldn't have to change anything else.
I haven't tried connecting to another Thingworx instance outside of my network yet. I'll try to find a server I can use. Is there a Thingworx instance hosted by PTC that can be connected to for testing purposes? Perhaps one made for the PTC University Thingworx tutorials?
I don't think we have one setup for testing/ connection purposes. If you don''t have access to our eSupport portal and the downloads, you can sign up for our Developer trial edition at the Developer Zone.
