File transfer subsystem Error Source file not found - Permissions Issue
While I am trying to copy file using File transfer Subsystem Copy from local to thingworx repository , I am getting error :
"File transfer subsystem encountered an error: Source file 'sourcefile' not found"
Does anyone know what Permissions are required to setup for this as if I use Administrator login to copy. It worked fine.
Harpreet
